rkadsit's avatar
rkadsit
Cannot download bootcode to GS724TP
I have downloaded upgrade files which included the bootcode for my GS724TP.  It needs version 1.0.0.5 before I can upgrade further.  Every time I try to download the file to the switch from my PC, it gives me a copy failed.  Is that a problem with the file I downloaded or something else.
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    Hi rkadsit,
    Here's what I found on the release notes that you can try.
    • To update boot code:
      • If the switch has firmware version 1.x, log into the switch’s GUI, go to Firmware > File Management > File Download. Follow the instructions to download boot code version version 1.0.0.5 to the switch.
      • If your switch has firmware version 2.x, log into the switch’s GUI, go to Maintenance > Download. Follow the instructions to download boot code version version 1.0.0.5 to the switch.
        After download completed, reboot the switch. When the switch booted up, verify from the GUI the switch’s boot version has been upgraded to v1.0.0.5 before proceeding any further.
    • If the switch has firmware version 1.x, the switch must be upgraded to the interim image (GS700TP_V1.0.0.inter.ros) first. Then, perform the upgrade again from the interim image to V3.0.6.1.
    • The procedure for upgrading the device to the interim image is the same as the regular firmware upgrade. It can be downloaded to the switch by using the GUI via a TFTP server or by using Smart Wizard Discovery utility.
    Here is the link for reference. If ever that it is still not working, try to reset it to factory default and see how it goes from there.
    Regards.
    • rkadsit's avatar
      rkadsit
      Thanks for responding JohnCarloV, but I already tried that very same procedure.  The problem is I get an error that the copy to the switch failed.  I used the HTTP transfer method from my PC.
      Bob
      • JohnC_V's avatar
        JohnC_V
        rkadsit,
        Please do try using TFTP download. Here is the TFTP server that we use.
        You may also follow this article.
ProSupport for Business
