storminnorman
Aug 25, 2016Aspirant
Can't Ping PC on switch
I have a GS110TP wiht two Windows 7 comptuers attached. I can ping oen but not the other. I checked the ports configurations and they are the same
The one I cn ping is on port 7 and the 1 I can't ping is in port 8
ANy ideas
- JohnRoNETGEAR Employee Retired
Hello storminnorman,
Welcome to the community!
Did you check if the other win7 computer is getting an IP address? If so, check if that computer can ping your gateway or DHCP server.
Thanks,
- storminnormanAspirant
Yes the PC gets an IP and can access the network. I am goign to try swithcing the ports on the switch wiht the other PC that I can ping and see if that makes a difference
And the firewall is off...
Update on this case.
The issue is with both PC's and it seems that the DNS is not being updated on our servers possibly the "switch" needs to be added as a DHCP relay.
DHCP shows the correct address but the DNS server shows a different address. DHCP is coorect
