Hisham_Nagia
Aug 26, 2017Follower
Compatibility Information Needed
Hello , I have big project ( complete industrial complex ) includes building a number of physically separated LANs to host data ( PC / Servers / Printers ) , IP Camera Surveillance , Industrial Machines , Access control finger print devices , fire fighting boards communications , telephony over fiber communications , I have selected the following LAN switches to build the project as follows :
* M4300-12X12F ( XSM4324S-100NES ) - as aggregation point(s)
* S3300-28X-PoE+ ( GS728TXP ) - for IP Camera Surveillance
* GS728TP - for ordinary data + access control + industrial machines ...
I am intending to use single mode fiber optic cables OS2 (10G Speed Capable ) to run 1G fiber communications between switches at the moment ( star network ) and in the future to upgrade to 10G ( on SFP / GBIC level at need ) .
My Questions are :
* I am intending to use SFP / GBIC Netgear AGM732F ( 1G ) at all switches listed above , is this module compatible with the 3 models of LAN switches above ( I can have distance up to 1.5 KM per link ) .
* I am intending to use the following SFP/GBIC Netgear AXM762 ( 10G ) at need , is this module compatible with the XSM4324S-100NES and GS728TXP ( I can have distance up to 1.5 KM per link ) .
Thanks .
1 Reply
- HopchenProdigy
Hi,
In the future, you can simply have a look in the datasheets to see if something is compatible.
The datasheet for the M4300-12X12F
http://www.downloads.netgear.com/files/GDC/datasheet/en/M4300.pdfThe switch is compatible with both fibre modules you mention.
The datasheet for the S3300-28X-PoE+
http://www.downloads.netgear.com/files/GDC/datasheet/en/S3300_GS728TX_GS728TXP_GS752TX_GS752TXP.pdfThe switch is compatible with both fibre modules you mention.
The datasheet for the GS728TP
https://www.downloads.netgear.com/files/GDC/datasheet/en/GS516TP-GS728TP-GS728TPP-GS752TP.pdfThe switch is compatible with the AGM732F.
Cheers
