SS-SysAdm
Sep 30, 2024Aspirant
Configure SSL/HTTPS for GS724TPV2 and GS752TPv3
Hi All, I am looking to enable HTTPS for all my Netgear Switches (GS724TPV2 and GS752TPV3). But I cannot import the self-signed certificate that I have already got available. I feel like I'm missing a vital step, and was wondering if someone is able to help me on this? Looking forward to hearing some advice. Cheers!
- RylieColetteAspirant
Have you verified that the certificate matches the required key length and signature algorithm supported by the Netgear switches?
- SS-SysAdmAspirant
Hi RylieColette, we use a length of 2048, which I believe is good for Netgear devices.
- BrianLNETGEAR Moderator
Hi SS-SysAdm,
Welcome to the community!
To import self-signed certificates for your NETGEAR switches GS724TPV2 and GS752TPV3, follow these steps:
For GS752TPV3:
Log in to the switch: Open a web browser and enter the IP address of your GS752TPV3 switch.
Navigate to the certificate settings: Go to LAN Setup > Certificates1.
Import the certificate: Select the Import option and upload your self-signed certificate file1.
Enter the public and private keys: If required, paste the public and private key information from your certificate file1.
Save the changes: Make sure to save and apply the changes.
For GS724TPV2:
Log in to the switch: Open a web browser and enter the IP address of your GS724TPV2 switch.
Navigate to the certificate settings: Go to LAN Setup > Certificates.
Import the certificate: Select the Import option and upload your self-signed certificate file.
Enter the public and private keys: If required, paste the public and private key information from your certificate file.
Feel free to ask if you encounter any issues or need further assistance!
Kind regards,
BrianL
- RylieColetteAspirantHave you verified that the certificate matches the required key length and signature algorithm supported by the Netgear switches?
