Cloud33
Jun 01, 2018Follower
Connecting a Netgear M4300 to a HP Procurve
Hi,
I currently have 4x pro curve`s all running a mesh between them and I have a stacked pair of M4300`s going in soon. How would i configure one of the ports to connect to the HP and carry ALL...
DaneA
Jun 04, 2018NETGEAR Employee Retired
Hi Cloud33,
Welcome to the community! :)
The port on the M4300 stack that is connected to the HP Procurve should be:
a. set as a tagged (T) port
b. should be a member of all VLANs
c. set the PVID to 1.
As reference, kindly access the article below:
How do I setup a VLAN trunk link between two NETGEAR switches?
DaneA
NETGEAR Community Team
- DaneAJun 11, 2018NETGEAR Employee Retired
I just want to follow-up on this. Let us know if you have further inquiries.
Otherwise, if ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
