Net-Gear-Man
Apr 15, 2016Guide
Copy configuration from ProSafe GS748Tv5 to ProSafe GS752TP
Hi I am running a ProSafe GS748Tv5 (firmware 6.3.1.4) and was wondering if there's a way to copy the config over to a ProSafe GS752TP (firmware 6.0.1.16). I can copy/restore the config from the...
- Apr 15, 2016
Hello Net-Gear-Man,
Even though the GS748Tv5 and the GS752TP belong to the same switch family (Gigabit Smart Switch) they cannot use a config file from another model. As you can see, the GS752TP is a PoE switch so it has its own configuration script designed specifically for its function. Some of the scripts are not available on the GS748Tv5 and they have different headers as mentioned in the error message. Also, it is always required to have at least the same firmware version when restoring configuration files.
Let us know if you have more questions.
Thanks,
JohnRo
Apr 15, 2016NETGEAR Employee Retired
Hello Net-Gear-Man,
Thanks,
Net-Gear-Man
Apr 15, 2016Guide
Hi JohnRo.... Thanks for the info :).
- JohnRoApr 15, 2016NETGEAR Employee Retired
Hi Net-Gear-Man,
No worries! Have a great day! :)
Thanks,
