Kerberos07
Oct 05, 2017Follower
DHCP Relay Problem
Hi, I installed Netgear M7300-24XF switch as a Backbone and I established 5 VLAN connections to this switch. VLANs are running smoothly. I set DHCP Relay to the Windows Server 2012 DHCP server. ...
JohnC_V
Oct 06, 2017NETGEAR Employee Retired
Hi Kerberos07,
Welcome to our community!
I suggest you to open a chat / case online on NETGEAR support so that we can take advantage of your free support. Most likely, the clients are the one requesting an IP from the DHCP server.
- May 22, 2011Retired_Member
