ldh2002
Nov 06, 2017Aspirant
DHCP through GS108Tv2
Dear community, I am running into a problem with DHCP in my home network. My DHCP server is a Fritz!Box 7490. Several devices are connected through a GS108T. It seems that devices connected thr...
- Nov 06, 2017
Hello community,
I was actually able to resolve the issue myself.
To my embarrassment I noticed that the DHCP filter was enabled but no port was set to trusted.
Disabling the filter or trusting the port to the router gets the DHCP replies forwardet to the DHCP clients.
Cheers
ldh2002
TheEther
Nov 06, 2017Guru
Might want to try doing a factory reset. It should operate like a unmanaged switch with default settings.
