GregAdno
Sep 30, 2024Aspirant
Disableing RSTP on specific ports GS308T
Hi I have a situation where I need to disable RSTP on 2 ports on my GS308T switch, as these ports directly connect to devices which do not support RSTP, unfortunately I cannot seem to find a way to modify the RSTP settings on the port level?
does anyone know a way to do this?
Only see this mentioned for full managed switches:
I don't see this model being included.
Might check the user manual to see if there is any user configurations for RSTP for this model switch.
- GregAdnoAspirant
Hi it does have RSTP configuration options but it sems l;ike the RSTP is global, while some of the other Spanning Tree protocols also have port specific options??
i
- ErwinLNETGEAR Moderator
Hello GregAdno
And welcome to the NETGEAR Community! 🙂
You can disable Rapid Spanning Tree Protocol (RSTP) on a port level for the Netgear GS108T. Here are the steps to do so:
1. Log in to the switch’s web interface.
2. Navigate to Switching > STP > CST Port Configuration.
3. Select the port you want to configure.
4. Change the STP status to “Disable”.
5. Apply the changes.Have a lovely day,
Erwin
Netgear Team
