VincentKhoo
Jan 09, 2019Aspirant
Does Netgear managed switch support putty ssh with auto command file
Hi,
i am running a system to have different bat file command to run putty with ssh, example like : putty.exe -ssh user@switch-ip -pw password -m C:\temp\commands.txt, the purpose is that I need to change vlan port upon request automatically. Does Netgear managed switch support this function?
Thank you
Vincent
- JohnC_VNETGEAR Employee Retired
Hi VincentKhoo,
Welcome to our community! :)
I did inquire your case and as per our engineering team, this function is not supported in our switches.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
I would like to have a follow up on the thread that you posted. Please let us know if everything is ok now or you still need further assistance.
