C-Surfing
May 14, 2023Aspirant
[DOT1x] How can i disable the Dot1x in gs724t
hi,guys i have had a problem, we started dot1x on all switchs most are HUAWEI,and we found Dot1x packet can't forward across Netgaer switchs,i have searched in bing.com,and i just get some to en...
- May 16, 2023
Which of the one or up to two decades old GS724T are you referring to here?
C-Surfing wrote:
the default settings of dot1x and radius are all disabled,
This is probably correct.
C-Surfing wrote:
it is no matter,i will config it, i just dont like config in web
Can't follow you here, not sure on how we should help then.
Always confused about the design behind such ideas. dot1x is for the "last" or first device in the line by design. If magically forwarding this, many issues and risks arise. Say you have some more "core" switches taking care of dot1x, but connect many clients like on a hub (or for the sake you name it unmanaged) each of these devices can transmit EAPOL-Logoff frames ... and you end with all connections on that core switch terminated.
C-Surfing
May 16, 2023Aspirant
thank you
the default settings of dot1x and radius are all disabled,it is no matter,i will config it, i just dont like config in web
schumaku
May 16, 2023Guru - Experienced User
- C-SurfingMay 17, 2023Aspirant
yes,sir
forgive me bad english
the model is GS724Tv3 24Port
i am in China,we use HUAWEI Network Devices.and those netgear sws be used as no-configuration we bought years ago,it be linked as access-mode
if switch receive multicast of dot1x packet,it will sent packet to cpu,so we have failure of dot1x.but in HUAWEI we can use command to change it ,the packet will be forward to Upper-level switch. so i want to know if netgaer have some setting also
