sahas1
May 12, 2025Aspirant
Dynamic RAM in GSM4352V1
I have a switch with serial 7FX13C5SA0330. I want to know the amount of dynamic ram (DRAM) that is available in the switch.
I tried the checking the switch but it only shows CPU RAM which is just under 2 Gigs and approximately 1.4 G is in use and approximately 0.5 is free. Refer red color highlighted data from switch.
I wish to know the amount of DRAM available with the switch
*************** show process memory ***************
Total: 1989828 KB
Allocated: 1466668 KB
Free: 523160 KB
Component CurrentAllocated[change] MaxAllocated[Allocs/Frees]
1 - SIM 5335463[+5335463] 6032587 [1946/32]
2 - NIM 1114617[+1114617] 1114617 [20/0]
3 - TRAPMGR 3376[ +3376] 3376 [1/0]
5 - CNFGR 27924[ +27924] 27924 [132/0]
6 - DRIVER 61749969[+61749969] 61757283 [4028/635]
7 - POLICY 42620[ +42620] 42620 [2/0]
8 - DOT1Q 6846572[+6846572] 6846572 [16/0]
9 - PBVLAN 3496[ +3496] 3496 [1/0]
10 - DOT3AD 410096[ +410096] 410096 [6/0]
11 - STATSMGR 20310236[+20310236] 20310236 [8/0]
14 - USMDB 964896[ +964896] 964896 [2/0]
17 - FDB 2263748[+2263748] 2263748 [10/0]
18 - GARP 4169790[+4169790] 4169790 [20/0]
19 - SNMP 9504[ +9504] 11848 [23/4]
20 - DTL 721432[ +721432] 721432 [22/0]
21 - USER_MGR 87056[ +87056] 87056 [3/0]
22 - CLI_WEB 11439444[+11439444] 11812164 [35657/11537]
24 - IP 22946645[+22946645] 22946661 [96/57]
25 - RTR_DISC 36200[ +36200] 36200 [4/0]
27 - RIP 187181[ +187181] 187181 [12/0]
28 - IGMP 16875708[+16875708] 16875708 [4/0]
29 - MCAST 66474024[+66474024] 66474024 [20/0]
30 - PIMDM 47068[ +47068] 47068 [2/0]
31 - DVMRP 108[ +108] 108 [1/0]
32 - PIMSM 88300[ +88300] 88300 [2/0]
33 - IPSLA 30572[ +30572] 30572 [2/0]
34 - VRRP 42366664[+42366664] 42366664 [2776/0]
38 - QOS_ACL 33483976[+33483976] 33483976 [21/0]
39 - QOS_COS 503800[ +503800] 503800 [4/0]
40 - QOS_DIFFSERV 138367504[+138367504] 138367504 [51/0]
41 - PORT_MIRROR 2804[ +2804] 2804 [2/0]
42 - MFDB 2312080[+2312080] 2312080 [3/0]
43 - FILTER 1422452[+1422452] 1422452 [5/0]
44 - IP_HELPER 385532[ +385532] 385532 [136/0]
45 - SNOOPING 19210837[+19210837] 19210837 [130/0]
49 - DOT1S 83994901[+83994901] 83994901 [707/0]
50 - RADIUS 2350072[+2350072] 2350072 [3/0]
51 - TACACS 372276[ +372276] 372276 [3/0]
52 - DOT1X 6081363[+6081363] 6081363 [17/0]
53 - MAB 5547920[+5547920] 5547920 [13/0]
54 - DHCPS 19072496[+19072496] 19072496 [4/0]
55 - DVLANTAG 24600[ +24600] 24600 [2/0]
58 - SSLT 1584[ +1584] 1584 [1/0]
59 - SSHD 42044[ +42044] 42044 [2/0]
62 - UNITMGR 26596[ +26596] 26596 [6/0]
63 - CARDMGR 209880[ +209880] 209880 [20/0]
64 - STACKING 8192[ +8192] 8192 [1/0]
65 - EDB 3520[ +3520] 3520 [55/0]
68 - FFTP 50800[ +50800] 50800 [1/0]
69 - OSAPI 177859321[+177859321] 177859321 [4714/119]
70 - POE 223776[ +223776] 223776 [3/0]
71 - SCRIPT 0[ +0] 120 [10/10]
72 - LOG 163132[ +163132] 163132 [5/0]
74 - OUTBOUND_TELNET 112[ +112] 112 [1/0]
75 - PORT_MACLOCK 26732792[+26732792] 26732792 [240/0]
77 - DENIAL_OF_SERVICE 19648[ +19648] 19648 [2/0]
83 - OSPFV3 169271[ +169271] 169271 [17/0]
84 - IPV6 1743178[+1743178] 1743178 [28/0]
85 - RLIM 3396[ +3396] 3396 [6/0]
86 - DHCP6S 522932[ +522932] 522932 [265/0]
87 - LLDP 6867302[+6867302] 6867302 [24/0]
88 - IP_SUBNET_VLAN 8936[ +8936] 8936 [4/0]
89 - MAC_VLAN 170488[ +170488] 170488 [10/0]
90 - PROTECTED_PORT 528[ +528] 528 [1/0]
92 - DNS_CLIENT 378752[ +378752] 378752 [14/0]
94 - BSP 1424[ +1424] 1424 [8/0]
96 - MFC 1284096[+1284096] 1284096 [2/0]
97 - VOICE_VLAN 160272[ +160272] 160272 [8/0]
98 - DHCP_SNOOPING 4767440[+4767440] 4767440 [15/0]
99 - DYNAMIC_ARP_INSPECTION 3235752[+3235752] 3235752 [7/0]
100 - QOS_VOIP 91152[ +91152] 91152 [6/0]
101 - SFLOW 554888[ +554888] 554888 [14/0]
102 - CAPTIVE_PORTAL 9702174[+9702174] 9702174 [33/0]
103 - ISDP 2484003[+2484003] 2484003 [9/0]
104 - MGMT_ACAL 25362[ +25362] 25362 [3/0]
105 - BOX_SERVICES 160[ +160] 160 [1/0]
107 - QOS_ISCSI 314732[ +314732] 314732 [6/0]
108 - RMON 8869352[+8869352] 8869352 [17/0]
115 - AUTO_INSTALL 3480[ +3480] 3480 [1/0]
116 - DHCP_CLIENT 229000[ +229000] 229000 [1006/0]
117 - BOOTP_CLIENT 3376[ +3376] 3376 [1/0]
118 - CAPTIVE_PORTAL_WIRED_INTF_OWNE 203760[ +203760] 203760 [11/0]
119 - DHCP6_CLIENT 1164[ +1164] 1164 [11/0]
121 - PRIVATE_GROUP_VLAN 51486[ +51486] 51486 [2/0]
122 - CHECKPOINT_SERVICE 8192[ +8192] 8192 [1/0]
123 - ARP 1015808[+1015808] 1015808 [4/0]
124 - MVR 1269554[+1269554] 1269554 [11/0]
127 - LLPF 868[ +868] 868 [1/0]
129 - TIMERANGES 162500[ +162500] 162500 [4/0]
131 - GREENETHR 224244[ +224244] 224244 [5/0]
132 - MRP 21588[ +21588] 21588 [2/0]
133 - MMRP 2636172[+2636172] 2636172 [690/0]
134 - MVRP 8500820[+8500820] 8500820 [688/0]
135 - MSRP 60281040[+60281040] 60281040 [1718/0]
136 - DOT1AS 16346352[+16346352] 16346352 [5/0]
138 - USBFLASHDRIVE 576[ +576] 576 [1/0]
142 - OPENFLOW 3704480[+3704480] 3704480 [34/0]
143 - PFXLIST 10272[ +10272] 10272 [2/0]
144 - ROUTEMAP 2584[ +2584] 2584 [2/0]
145 - PBR 57852[ +57852] 57852 [1/0]
146 - UDLD 1196323[+1196323] 1196323 [6/0]
150 - RPC_SERVER 787546[ +787546] 787546 [9/0]
151 - RPCAP 23296[ +23296] 23296 [6/0]
152 - RMT_SESSION 100[ +100] 100 [1/0]
153 - STATS_APP 6721528[+6721528] 6721528 [11/0]
154 - OpEN_API 180816[ +180816] 180816 [10/0]
155 - PROC_MGR 0[ +0] 753 [8/8]
156 - AUTHMGR 27349075[+27349075] 27349075 [26/0]
159 - RAGUARD 160[ +160] 160 [2/0]
165 - DAS 1107584[+1107584] 1107584 [8/0]
171 - LOOP_PROTECT 60156[ +60156] 60156 [3/0]
175 - USERAPP_CFG_DB 690[ +690] 690 [24/0]
181 - PTP_TC 30672[ +30672] 30672 [4/0]
182 - INTERFACE_APPLICATION 38784[ +38784] 38784 [3/0]
191 - BONJOUR 65708[ +65708] 65708 [4/0]
197 - IPV4_DEVICE_TRACKING 2025288[+2025288] 2025288 [8/0]
198 - REDIRECT 5760[ +5760] 5760 [2/0]
199 - ARP_GUARD 1426572[+1426572] 1426572 [6/0]
202 - EAP_INFRA 105000[ +105000] 105000 [2/0]
207 - NTP 1176[ +1176] 1176 [3/0]
208 - SMTP 2451440[+2451440] 2451440 [2/0]
Total Current Usage = 962695151
osapi Debug overhead = 5558144
Hello sahas1 , welcome to the Netgear Community!
The physical memory is documented in the https://www.downloads.netgear.com/files/GDC/M4350/M4350_Datasheet.pdf
p.55What is effectively available is the number shown on top of your listing.
Any specific issue you like to discuss?
-Kurt.
- sahas1Aspirant
The system memory(RAM) of 2GB is the dynamic ram (DRAM) for this switch? If no, what is the value of the Dynamic RAM?
Yes, as such devices don't have virtual memory.
