Amir_1982
Jul 05, 2018Follower
EOL Network Switches
HI
please clarify is model M530028G3 (GSM7328Sv2h2) end of sale?
Best regards
Amir
JohnC_V
Jul 06, 2018NETGEAR Employee Retired
Hi Amir_1982,
Welcome to our community! :)
GSM7328S products are EOL. The replacement for this unit is the M4300-28G (GSM4328S).
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
