MM_tech
Nov 30, 2018Aspirant
ERROR: can't get kernel image!
Hi,
Overnight switch malfunction. I managed to connect to the switch with miniUSB console port using HyperTerminal port 23. I switched off/on couple of times. This is the error logs i get. :(
Please help. I am attaching the pictures of switch too.
U-Boot 2012.10-00205-gef56c5f (Jan 01 2016 - 14:02:15)VerNo=1.0.0.7
UBIFS error (pid 0): ubifs_get_sb: cannot open "ubi:fs", error -19
UBIFS error (pid 0): ubifs_mount: Error reading superblock on volume 'ubi:fs' er
rno=-19!
ubifsmount - mount UBIFS volume
Usage:
ubifsmount <volume-name>
- mount 'volume-name' volume
UBIFS not mounted, use ubifs mount to mount volume first!
ubifsload - load file from an UBIFS filesystem
Usage:
ubifsload <addr> <filename> [bytes]
- load file 'filename' to address 'addr'
Wrong Image Format for bootm command
done
Usage:
Saving Environment to SPI Flash...
done
Usage:
ERROR: Ethernet external port not connected
at bcmiproc_eth.c:125/bcmiproc_eth_open()
ERROR: can't get kernel image!"
Thank you
MM
- MM_techAspirant
Sorry for the VERY late update on my case. My Netgear case was a power unit issue that was escalated to their level 3 engineering team who has confirmed it was not fixable. It was covered under the device warranty
- DaneANETGEAR Employee Retired
Hi MM_tech,
Welcome to the community! :)
Kindly access the article below and follow the initial steps but select option 9, to try to activate a backup image. If ever this works then the firmware image is corrupted on the now non-active partition.
M4300 - Resetting to factory default using the boot menu
Let us know how it goes.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
- boeLuminary
How do you reset to factory default from the boot menu.
As mentioned before: Strictly follow M4300 Resetting to factory default using the boot menu
Keep in mind "factory default" means an empty config file.
