peos42
Oct 24, 2024Tutor
Faulty performance specs on MS510TXUP ?
Hi I think of buying a MS510TXUP switch. But the spec says it has only 14.8 Mpps packet forwarding rate. That would at 64byte packets give a 10Gbit/s packet rate for the whole switch. A switch th...
- Nov 18, 2024
Hi
If someone is interested.... I have got a reply now from Netgear backline.
--snip--
Our engineers did some test on the MS510TXUP, they confirmed that the forwarding rate of total system is 104.17 Mfps.
--snip--
That sounds like a more reasonable value than the spec sheet 14.8 Mfps.
So the official spec sheet of MS510TXUP is wrong!
NOW I can buy a bunch of these 🙂
schumaku
Oct 25, 2024Guru - Experienced User
Looks like a typo on the data sheet to me. Operating a bunch of MS510TXUP on 10 Gb networks, trouble-free..
peos42
Oct 25, 2024Tutor
Hi and tnx for the answer.
Can you in some way verify that you have passed this 10Gbit/s total limit (i.e 14.8 Mpps packet forwarding rate) that according do spec exists for the whole switch (limit if all packeds are 64byte of course). Of course it is hard for you to guarantee this as there are also bigger packages than 64byte going over the wire. But as you have this particular switch, can you say something more about its performance.
I have asked Netgear about this, but have not yet got any answer. So I thinking back and forth if I dare to buy it before Netgear give me he answer...
//Peo
