Milesdeep's avatar
May 25, 2016
FS728TP Switch-How to set IP for VLAN
I have the above mentioned switch and I can find where to create the various VLANs, I just cannot figure out how to route between the VLANs.  How do I assign the VLAN an IP?
  • JohnRo's avatar
    JohnRo
    May 26, 2016
    Hello Milesdeep,
    Welcome to the community!
    The FS728TP is only a layer 2 Smart Switch, such features like Inter-VLAN routing are not available on these models. You will find Inter-VLAN feature on a router with VLAN capability (VLAN aware) or a Layer 3 switch. For more information about Smart Switches please click here.
    Thanks,
  • I read that there is a "Routing" tab.  I don't have one.  I try to update the firmware but it says my unit is up-to-date.  Inter-VLAN routing?  Maybe not on this model?  So, what's the point of VLANs if you can't route between them?
    • JohnRo's avatar
      JohnRo
      NETGEAR Employee Retired
      Hello Milesdeep,
      Thanks,
    • JohnRo's avatar
      JohnRo
      Hi Milesdeep,
      We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
      If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
      Thanks,
      • Milesdeep's avatar
        Milesdeep
        Tutor
        Thanks for the comments, I didn't not know it was a layer-2.  I'll work accordingly.  Thanks.
ProSupport for Business
