TedW's avatar
TedW
Global L2 Loop Protection question on M4300-52G-PoE+
I was testing the L2 Loop Protection capability of my M4300-52G-PoE+ stack by connecting ports 4/0/1 and 4/0/5 together, and the protection seemed to work great, putting port 4/0/1 in a D-Disable sta...
  • TedW's avatar
    Aug 10, 2017
    Nevermind.  After doing some additional digging, I found the option to reenable the port under Switching -> Ports, so I was able to answer my own question.
ProSupport for Business
