TedW
Aug 10, 2017Aspirant
Global L2 Loop Protection question on M4300-52G-PoE+
I was testing the L2 Loop Protection capability of my M4300-52G-PoE+ stack by connecting ports 4/0/1 and 4/0/5 together, and the protection seemed to work great, putting port 4/0/1 in a D-Disable sta...
- Aug 10, 2017
Nevermind. After doing some additional digging, I found the option to reenable the port under Switching -> Ports, so I was able to answer my own question.
TedW
JohnC_V
Aug 10, 2017NETGEAR Employee Retired
Hi TedW,
Thank you for sharing the solution to the community! We look forward hearing more solutions and being helpful resource in the future!
