somnus1654
Oct 22, 2017Aspirant
GS105Ev2 logon access
Hi, im just buy 2 of this switches to improve vlans for practice. I reboot the switches holding the reset button in the back side. It look like the reboot apply well, all the leds turn in for 2 se...
JohnC_V
Oct 24, 2017NETGEAR Employee Retired
Hi somnus1654,
Welcome to our community!
Basically, the default password is password. If it is not working, please try to download the latest version of the Prosafe utility.
You may download it here.
somnus1654
Oct 26, 2017Aspirant
i reboot a lot of times but don't work
- JohnC_VOct 26, 2017NETGEAR Employee Retired
Try pressing and holding the reset button for about 10-15 seconds, then reboot. I believe this is a brand new unit, you may also open a chat / case online on NETGEAR support and please let them know the status of your switch.
- somnus1654Oct 26, 2017Aspirant
i try to reboot for 15 seconds and for more time, but i can
this switch i bought 4 years ago and the support section ask me the ticket of bestbuy
i dont have it anymore
Try to access the switch via web browser and see if that will change the result.
