somnus1654
Oct 22, 2017Aspirant
GS105Ev2 logon access
Hi, im just buy 2 of this switches to improve vlans for practice. I reboot the switches holding the reset button in the back side. It look like the reboot apply well, all the leds turn in for 2 se...
somnus1654
Oct 26, 2017Aspirant
i reboot a lot of times but don't work
JohnC_V
Oct 26, 2017NETGEAR Employee Retired
Try pressing and holding the reset button for about 10-15 seconds, then reboot. I believe this is a brand new unit, you may also open a chat / case online on NETGEAR support and please let them know the status of your switch.
- somnus1654Oct 26, 2017Aspirant
i try to reboot for 15 seconds and for more time, but i can
this switch i bought 4 years ago and the support section ask me the ticket of bestbuy
i dont have it anymore
- JohnC_VOct 26, 2017NETGEAR Employee Retired
Try to access the switch via web browser and see if that will change the result.
- somnus1654Oct 27, 2017Aspirant
Hi, i try to access via webpage but can't login.
i use de admin: admin
Password: password
i try a lot of combinations on both switches that i have but don't work.
could you send me another possible combinations of users and pass?
thx 4 ur help
