Machtl
Apr 01, 2016Aspirant
GS105Ev2 turn off EEE?
Hi, we're currently searching for a small 5 port gigabit switch were it is possible to turn off all the EEE settings, etc. so, no Energy Efficient Ethernet stuff or Short Range etc. Is this...
JohnRo
Apr 01, 2016NETGEAR Employee Retired
Hello Machtl,
Welcome to the community!
The firmware version 1.4.0.6 has an added feature to allow you to enable/disable power saving mode. DoS protection is automatic, I don't see a way to disable this on the switch. There are also some models (GS716Tv3, GS724Tv4, and GS724Tv5) which totally support disabling and enabling Sleep (Auto-power-down) Mode and EEE mode.
I hope this helps. Let us know if you have more questions.
Thanks,
Machtl2
Apr 04, 2016Aspirant
ok, but disables this "power saving mode" also EEE on the switch? its a little unclear what "power saving mode" means...
thx!
- DaneAApr 04, 2016NETGEAR Employee Retired
Hi Machtl,
If there is no RJ45 ethernet cable is connected, the GS105Ev2 switch will go into power saving mode. The switch will just resume normal operation when an ethernet cable is plugged-in to it.Regards,DaneA
NETGEAR Community Team
