AkeRolf
Jan 23, 2017Follower
GS105ev2 disable EEE mode
Is it possible to disable EEE mode or not?
You can disable Power Saving Mode....does that mean that EEE i disabled!
Hi AkeRolf,
Welcome to NETGER's Online Community!
Per my understanding of the User Manual, turning off Power Saving mode on GS105Ev2 system also turns off Short Cable, Link-Down and EEE Power saving features too on the same system.
However, you can still wait for further explanation from others.
I hope that helps.
Thanks
- Evans-oNETGEAR Expert
Hi AkeRolf,
I hope that helps.
Thanks
- XavierLLNETGEAR Employee Retired
HI AkeRoff,
EvansO is right the Power Saving option disables the EEE
Hope that it helps
Xavier Lleixa
NETGEAR CBU PLM
- tomboisseauAspirant
I am very confused. I have looked and looked in the Prosafe Plus Configuaration Utility v2.3.20 and, inspite of the mention on page 39 of the ProSAFE Plus Utility User Manual, Nov 2016, when I go to "System > Management > Power Saving Mode", the is NO power saving mode option. The only thing that appears there is "Loop Detection". I'm using a GS105E-200NAS (aka GS105Ev2) What am I doing wrong?
Thanks,
Tom
