wesback
Jan 04, 2018Aspirant
GS105PE - PoE Passthrough issue with Unifi Switch
Hi, I have a Unifi USW-8P-60 switch powering my GS105PE which works fine. However PoE Passthrough seems to be an issue, the LED on Port 1 keeps blinking and it doesn't power my Access Point which...
wesback
Thanks for the great explanation. Can't seem to find the class immediately but I'm guessing it is probably 4 looking at the other models. A day where you learn something is a good day đ
What's strange though is that is worked for a while.
Hopchen
Jan 05, 2018Prodigy
Hi again,
I can't really understand how it could have worked beforehand, if it did. It doesn't make sense - especially if it is a class 4 access point, which many APs are these days with wireless AC :) On some switches, you can limit the amount of power a device is allowed to receive and thus limit the reserved power budget to a given device. I am fairly certain the Netgear PLUS switches (such as the GS105PE) cannot do this.
It is actually fairly common that support get questions on this particular switch, so we know your situation well. There is not much you can about it, unfortunately.
Cheers
