TWART016
Aug 01, 2016Follower
GS108Tv2 no PoE
Hello, with the first Port I do not get any power over the port to an access point. With other switches of the series I get the power. With a PoE injector it works to. Firmware is the newst 5...
DaneA
Aug 04, 2016NETGEAR Employee Retired
Hi TWART016,
We’d greatly appreciate hearing your feedback letting us know if the information I’ve provided has helped resolve your concern or if you need further assistance. If ever your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
