Frankyv
Jun 03, 2016Follower
GS108v4 speed setting ports
Hello,
My question is: Is it possible to set a port of my switch to a fixed speed?
My problem is: A Samsung smart TV is connected to the switch. But about 5 minutes after switching on the TV a error message pops up that the network is not connected. I think that the switch changes speed at that moment. It is only a message because the network connection is never a problem. Every thing works fine, but I hate to have the error message each time I switch on the TV.
Can anybody help me?
- JohnRoNETGEAR Employee Retired
Hello Frankyv,
Welcome to the community!
This is only a pass-through switch, it does not have any management software or firmware. There is no option to set port speed for this device. It automatically detects the device connected to it and gives the proper speed. This device works on 10/100/100 Mbps.
Thanks,
Hello Frankyv,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
