lodesmets
Mar 24, 2023Aspirant
GS305EP and 802.1X access control
Hello, I'm trying to configure 802.1X access control on a GS305EP switch. According to this page it should be available. But the configuration page looks completely different than the screensho...
- Mar 30, 2023
lodesmets wrote:
If it isn't available for the Plus Switches GS3xxEP/EPP, it is no problem, I can use a different switch. But I do not trust the list of compatible switches.
The "Applies to" is more a reference at time of the KB entry creation than a complete list of switch models supporting 802.1x.
lodesmets wrote:
So is there a correct list of 802.1X compatible switches?
Can't find any list or more comprehensive overview.
All "Plus" switches should be left out of scope, because there is no 802.1x implemented as shown.
For consulting exact features supported, I suggest to review the complete product description Briefly scrolling over shows that 802.1x availability does start on small switches like the GS108Tv3, GS110TPv3, and the GS110TPP 8-Port Gigabit Ethernet
Smart Managed Pro Switch, some are PoE+ equipped, some come with SFP ports, many or all come with the optional Cloud Management.
schumaku
Mar 28, 2023Guru - Experienced User
Dear Logan,
Here is the reference - wrong in my opinion:
The mistake is in the reference to the Plus Switches GS3xxEP/EPP:
lodesmets
Mar 30, 2023Aspirant
Yes, indeed. I saw it here
It says that the article is applicable to the Plus Switches GS3xxEP/EPP.
