vinyladdict
Feb 08, 2024Aspirant
GS316EP - Disable IGMP Snooping on a single port?
Hello - Can I disable IGMP snooping on just a single port on the GS316EP? I want to leave it on for the rest of the ports. Thanks!
vinyladdict
Thanks. I’m not a network engineer and can’t answer your question. It’s a BlueSound NODE (N130) music streamer. If there is an affordable Netgear managed switch that you recommend that can disable snooping at the port level I’d appreciate it. I don’t want to turn it off for my whole network.
schumaku
Feb 14, 2024Guru - Experienced User
Look into the Netgear Smart Managed Switch product line. Don't have the exact feature sets and controls in my head anymore since suffering from two strokes some 20 months ago.
Already the small GS108Tv3 GS110TPv3 GS110TPP Smart Switches for example (User Manual linked for courtesy to the interested readers) do allow enabling/disabling IGMP Multicast (as well as MLD) by interface. Yes, screenshot taken from the bigger and much more powerful MS510TXUP, but hey, you get the idea.
Switching -> Multicast -> IGMP Snooping Interface Configuration
