ccklau
Feb 19, 2018Aspirant
GS724T - Set it to be a general switch without management
Dear All, My switch is GS724Tv4. Its Boot Version is B1.0.0.4 and its Software Version is 6.3.1.19. I would like to make sure that my switch is set to be a general 24-port switch without mana...
- Feb 20, 2018
Hi ccklau,
Welcome to our community!
It seems that the firmware is up to date. Just run the switch out of the box and it will work as an unmanaged switch. You may also try to set it to factory default just to make sure that everything is set.
JohnC_V
Feb 20, 2018NETGEAR Employee Retired
Hi ccklau,
ccklau
Feb 20, 2018Aspirant
Hi JohnCarloV,
Thanks for your advices.
Ccklau
Ccklau
- JohnC_VFeb 21, 2018NETGEAR Employee Retired
You may just follow this link for further instructions. How do I reset a smart switch to factory default settings?
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
