GDJ777
Dec 12, 2022Follower
GS724T Switch Hardware Version ID
I have a very similar problem to other posts ... inherited a Netgear GS724T smart switch but do not know the model version number and how to upgrade firmware. Below is a summary of the relevant switch status information for the GS724T I need to upgrade (I think this implies a V2 switch). Could some one help me and describe if I have to do the firmware updates serailly (in order) or is it OK to jump directly to the latest?
Product Name: GS724T
Firmware Version: V1.0.0_0429
Protocol Version: 2.001.002
DHCP: Disable
IP Address: 192.168.1.43
Subnet mask: 255.255.255.0
Default gateway: 192.168.1.1
MAC address: 00-14-6c-0a-33-15
P.S. I have a second GS724Tv3 with firmware version 5.4.2.30 (its up to date) and would like to get these synced in firmware so I can do some additonal troubleshooting.
Thanks
- Marc_VNETGEAR Employee Retired
@GDJ7777
Welcome to the Community!
Can you locate the label on the switch? From the version currently installed it might be a possible V1 or V2. It Usually says the version on the label GS724T-200***
Regarding update, the version is not showing as available but once we have determined the version of the switch it would be best to continue upgrading the switch in a ladderized manner.
HTH
We're facing some almost two decades old GS724Tv1 or v2 hardware platform.
-> https://www.netgear.com/support/product/GS724Tv1.aspx#download
-> https://www.netgear.com/support/product/GS724Tv2.aspx#download
Either way the Smart Wizard Utility https://www.netgear.com/support/product/Smart%20Wizard%20Utility.aspx is required.
For detailed insight, consult the "View Previous Versions" and the "View Current Version" - there are docs or readmes included.
For detailed actions or processes, please feel free to ask . I'll try to find some Netgear friends with insight.
Scratch the idea having same versions in sync - we it's about features/functionality and and probelm fixes.
