ganewson's avatar
ganewson
GS724TS Leds showing incorrect port speed
Hi
I've just installed 6 stacked GS724TS switches and the only thing I did was to allocate an Ip address to the master switch. Everything else was set to the defaults.
When devices were connected the leds were showing flashing yellow which indicates a speed of 10m and a few where flashing green which I would of expected for all the ports.
I've now fixed the port speed at 100m and have set random PC's network adpaters at the fixed speed of 100m full duplex and it's made no difference to the led's colour.
The ports showing the correct colour flashing leds have the same adapter and port settings as the ones that don't.
Any ideas anyone
Thanks
Gary
  • did you got switch interface and look at link speed. default should be Auto but could be different
  • Hi thanks for looking
    Sorry but by link speed do you mean port speed in port configuration, if so don't have auto option only 10m,100m and 1000m
  • yup.... if set to use 1000Mbps then should negotiate but some time negotiation issue can be a driver related issues on pc side.
ProSupport for Business
