joshabts
Feb 17, 2014Novice
GS724TS Questions
Hello: I am looking for some information from real-world experiences with the GS724TS switches. 1) How well does the HDMI "stacking" work on these? Any tips/experiences with this? 2) With HDMI...
Jedi_Exile
Feb 18, 2014NETGEAR Expert
2 additional things.
1. You can't have switch that are member of the same stack have uplinks between them, No LAG linked the member switches as you looping the same switch then.
Remember stacking results in global management of the single unit with member porviding port density. Stacking handles all communication between members for everything through the HDMI links on that model of switch.
You can have multiple port LAG trunk between 2 separate stacked setups.
2. There is limit on number of port per group. I think it is 6 ports per group on Smart switches and 8 port for managed switches. Beyond those density, you should start looking at 10G link since they do make 10G stacking smart switches GS728TXS and GS752TXS.
