joshabts
Feb 17, 2014Novice
GS724TS Questions
Hello: I am looking for some information from real-world experiences with the GS724TS switches. 1) How well does the HDMI "stacking" work on these? Any tips/experiences with this? 2) With HDMI...
rjt
May 21, 2014Tutor
Jedi_Exile wrote: Answers.
3) Not recommend on these model because lower processing power. You could try it, but based on experience, it will cause heavy CPU load and you will start to see issues. Possible on Managed switches.
One way to do LACP LAG across the smart switch would to increase port density on 1 switch only. So a 4 port LAG should have 3 of its member ports on 1 switch and 1 port on another switch in the stack. Overall, I would advise against this on smart switch will limited resources.
Did you measure CPU load via SNMP? If not, how did you do it? Or did you notice the slow web interface slow down even more?
