Granten's avatar
Granten
GS724Tv2 Invalid access IP address
Hello,   I have a problem. when i wanna login into my GS724Tv2 switch the message "Invalid access IP address" pops up. I had factory resetted the switch, but it don't helps.... The switch is on the...
  • DaneA's avatar
    DaneA
    Dec 29, 2015
    Hi Granten,
    You mentioned from your initial post that you have already factory reset the GS724Tv2.  It could be that you have press the reset button instead of the factory defaults button.  Kindly try to perform a factory reset again on the GS724Tv2 by pressing the factory defaults button.
    It is because if the GS724Tv2 has been factory reset properly, its IP address should go back to the default IP address which is 192.168.0.239.
    DaneA
    NETGEAR Community Team
ProSupport for Business
