mweisko
Jul 27, 2017Aspirant
GS728TP and Smart Control Center
I'm trying to get Smart Control Center to work on a Windows 2016 server. Smart Control Center will not find the adapter even if I use "run as administrator". I'm using the latest version of Smart Con...
Retired_Member
Jul 28, 2017Hi mweisko
Welcome to the community!
Could you please check whether install WinPcap at the same time? As WinPcap will help software to find network adapter.
If not, please install this software and try again.
Hope it helps!
EricZ
NETGEAR employee
