DrGerm
Jun 01, 2016Aspirant
GS748T v5 Managed Switch Randomly Disconnecting
I am having a problem with my network randomly going offline. I am trying to identify the culprit. Every time this happens, it's purely only affecting connected devices. WiFi devices are not affe...
- Jun 04, 2016
I noticed on a different log that my router was being blocked due to DOS attacks. And I had turned on Auto-DOS-Control. I turned that off. Things seem more stable. So, maybe that was part of the problem. I will have to rely on the router and server firewalls.
I still have some problems with some devices, so, trying to take things one step at a time, I did a factory default on the switch, will see if that fixes anything.
I'm still researching on how to set the time automatically. I've had problems before with a different network device that didn't have a correct time, so just want to rule that out.
Next step will be to plug those problem devices directly to the router to see if they still go offline.
DrGerm
Jun 04, 2016Aspirant
