tzaff
Mar 18, 2015Novice
GS748T v5 VLAN problems
Hi there, I have a Netgear newbie question: I'm trying to get this working: VLAN100 (used for LAN), Untagged Ports 1-24, Tagged Port 48 VLAN200 (used for Phones), Untagged Ports 25-46, Tagged Por...
fordem
Mar 18, 2015Mentor
VLAN200 (used for Phones), Untagged Ports 25-46, Tagged Port48
VLAN1 (default management), Untagged Port 47, Tagged Port48
What is port 48 being used for?
Both, vlan100 and 200 have a dhcp server running on it, well at least should...
Does this mean the switch is acting as the DHCP server, or do you have separate DHCP servers on each VLAN?
My problem, once I've done all the config, say on vlan100, the server uplink (port 1 or whatever <=24) seems to be ok,
How are you testing this?
