itc_apollonio
May 10, 2018Follower
GS752TP VLAN routing NO INTERNET
Hi,
I need to create a VLAN routing but following the instructions by manual or forums it doesn't work.
Here the situation:
VLAN default: IP address 10.4.1.0 sub 255.255.255.224 gateway 10.4.1.65
VLAN4: IP address 192.168.0.1 sub 255.255.255.0 gateway 192.168.0.1
In VLAN4 I have two PC connected to ports untagged n° 47 and n° 48 and another switch connected to port tagged n° 51.
In routing table I have following situation:
network address 10.4.1.64 - sub 255.255.255.224 - protocol local next hop interface VLAN1 - next hop IP 0.0.0.0 - preference 1
network address 192.168.0.1 - sub 255.255.255.0 - protocol local next hop interface VLAN4 - next hop IP 0.0.0.0 - preference 1
default route network address 0.0.0.0 sub 0.0.0.0 next hop 10.4.1.65 preference 1.
PC present on default VLAN haven't problems to communicate each other or to use internet.
PC present on VLAN4 can communicate each other but they can't use internet. In fact, I only ping 10.4.1.67 (switch address) but nothing else. What do I wrong?
I'd like to apologize for my English.
1 Reply
- Anonymous
Hi itc_apollonio,
Welcome to the community!
1. As VLAN1 clients can access each other and Internet----so Internet is ok, and VLAN1 config is OK.2. As VLAN4 client can access each other, but cannot access Internet----so VLAN4 config is OK. Maybe it's route problem. On the switch, you have add a default route, next hop point to the Gateway. So please check on the Gateway, whether there is back route to VLAN4 network(192.168.0.1/24, next hop point to 10.4.1.67) or not? If not, it should be the root cause.
Hope it helps!
EricZ
NETGEAR employee
