agarciar
Sep 11, 2025Follower
GSM4328S spuriously after powering up, shows power led amber on, and stucks
M4300 (GSM4328S) spuriously after powering up, shows power led amber on, and stucks. Need to disconnect and connect again power supply, and then works. I don't know if someone is experiencing this ...
Sep 11, 2025Guru - Experienced User
Same thing happen if you disconnect all cables from the switch and power ON.
Has a reset been performed and setup from scratch to see if problem continues?
Something to make contact with NG support about.
