Dansker
Mar 19, 2016Aspirant
GSM5212P spare part
Trying to order a replacement power supply board for a GSM5212P-v1h1. How do you go about that?
JennC
Mar 19, 2016NETGEAR Employee Retired
Hello Dansker,
NETGEAR does not replace any internal components of the product, what they do is replace the hardware itself.
Try getting to support center to check its warranty.
