vanya-sky
Aug 22, 2019Aspirant
Gsm7224p not web interface
I removed the “U” and “T” label on the Vlan of my ports. My web interface now does not work. What to do? My switch GSM7224p
- Aug 25, 2019
If you have powered off the switch it might well be that the configuration wasn't saved but was only applied in the so-called "running-config".
When that running configuration isn't save and the switch gets rebooted, all changes done without saving it afterwards get lost.
Concerning you post about doing a factory reset: You can do this over a serial console, but you wouldn't need to. Once you have a serial console working, you could have reconfigured the misconfigured port config later without losing the complete config.
You can export/backup the configuration of the switch via both Web and command line interfaces, this is also outlined in the manual.
vanya-sky
Aug 25, 2019Aspirant
Miracles. I arrived at the switch two days later, vlan1 "untag" was tagged. And the web interface has earned. I did not do anything.
