tim_
Jul 27, 2016Aspirant
GSM7224V2 fails to boot
Hi, I have a GSM7224 V2 switch and am trying to reset it to original unconfigured state. Howevr it completely fails to boot. When it is powered on the power LED quickly goes solid green (meanin...
- Aug 04, 2016
It seems the flash is corrupted and so it is being returned for a replacement. No way to fix this otherwise it seems.
DaneA
Jul 27, 2016NETGEAR Employee Retired
Hi tim_,
Welcome to the community! :)
Let me share the following links below as reference and it might help:
https://community.spiceworks.com/how_to/2923-what-to-do-when-my-managed-switch-does-not-boot
DaneA
NETGEAR Community Team
- tim_Jul 28, 2016Aspirant
Hi DaneA,
Thanks, they are both good articles that I hadn't found, but they only apply if the switch can boot to a menu. Mine is not giving me the menu. It powers on and gives me a short message (as per my first post) and then stops. No menu is ever presented.
What can I do?
Thanks,
Tim- DaneAJul 28, 2016NETGEAR Employee Retired
Hi tim_,
I suggest you to open an online case with NETGEAR Support at anytime. Let them know what happened to your GSM7224V2 switch for further assistance. If ever the device hardware is found faulty, then please be ready to submit a soft copy of the Proof of Purchase or Sales Invoice of your device for warranty verification via the online case. If the hardware warranty is still valid, then an online replacement will follow.
DaneANETGEAR Community Team
- DaneAAug 01, 2016NETGEAR Employee Retired
Hi tim_,
Just want to follow-up on this. Were you able to open an online case with NETGEAR Support? If yes, kindly keep us posted about the progress of your online case.
DaneA
- tim_Aug 01, 2016Aspirant
Hi DaneA,
Yes I've logged a case. Thanks for the pointer. If there is anything useful to report I will.
Tim
