BobbyR
Nov 25, 2012Aspirant
GSM7224V2 Web admin connection problems
Hello, I am having some issues with initial set and config. I was having problems getting the ezconfig routine to work through the serial cable connection. The switch would not accept any IP I trie...
jmizoguchi
Nov 25, 2012Virtuoso
Some model is different so didn't think used 169.
If you saved new ip for the device it should work.
Possible switch is not writing a new settings or something failing
