klqn
Apr 06, 2016Aspirant
GSM7248v1 VLAN for R6250 Router
Hi everyone, I am trying to configure a GSM7248v1 switch to work with my R6250 router (No VLAN aware router). I factory reset my GSM7248v1 and create only manage IP/Netmask/GW address. My PC conne...
- Apr 11, 2016
Thanks, It's out of warranty when we lost my proof my payment, eventhough we are the orginal owner. It's a diffrent between Cisco and Netgear, Cisco lifetime warranty without proof my payment, as for Netgear :(.
DaneA
Apr 06, 2016NETGEAR Employee Retired
Hi klqn,
Welcome to the community! :)
You mentioned that you are only getting 1MB/s speed when your PC is connected to the GSM7248v1. Kindly answer the questions below:
a. What is the behavior of the port LED light on the LAN port where your PC is connected to the GSM7248v1?
b. Have you tried using other LAN ports of the GSM7248v1? If yes, is it the same problem?
c. Are you using CAT5e or CAT6 ethernet cables?
d. Kindly access the web-GUI of your GSM7248v1, go to Switching > Ports > Port Configuration. Is the Admin Mode set to enable to all ports?
e. From question d, is the Physical Mode set to Auto on all ports? What are the other options on it?
I look forward to your response.
DaneA
NETGEAR Community Team
klqn
Apr 08, 2016Aspirant
Thanks for getting back to me.
I found the CoS cause the speed problems, after I changed/save configuration and reboot my switch, I am longer have access to the serial console. I think the bootloader is corrupted. Is there a bootload I can download?
thanks
- DaneAApr 11, 2016NETGEAR Employee Retired
Hi klqn,
Let me share this article below. Kindly try to follow the procedure and it might help:
What do I do when my GSM managed switch does not boot up?
DaneA
NETGEAR Community Team- klqnApr 11, 2016Aspirant
DaneA,
Do you you have bootloader (gsm72xxxxx.stk) for GSM7248v1? I think I need to fix the bootloader by XMODEM or reprogram it with the programmer. programmer = desolder the SST 39VF040 70-4C-NH, put it on the IC programmer in my lab. Once I get my bootloader load up via console, I can for XMODEM or tftp to flash the switch firmware. All I need is a "bootloader (gsm72xxxxx.stk) for GSM7248v1".
thanks for you help.
Flash memory for bootloader
Flash for firmware.
Hi klqn,
I am not sure if there is a bootloader available for the GSM7248v1 switch. I suggest you to open an online case with NETGEAR Support and inquire if there is a bootloader for the GSM7248v1.
Also, just a reminder, the warranty of the GSM7248v1 will be void if you desolder some components of it.
DaneA
