Thornweb
May 05, 2017Aspirant
GSM7312 Bricked???
Just upgrade my GSM7312 via TFTP from version 3.xxx to the latest version on the downloads site, it now just constantly loops round booting up. Can i upgrade via the console port and reset it to ...
DaneA
May 08, 2017NETGEAR Employee Retired
Hi Thornweb,
Welcome to the community! :)
It is not recommended to upgrade the firmware from v3.x.x.x straight to the latest v6.2.0.14. The advisable way is to upgrade the firmware in a ladderized manner. For example, v3.0.3.2 to v5.1.1.3 then from v5.1.1.3 to v6.0.0.15 and so on until you reach the latest firmware version.
Kindly access the articles below that I found online and follow the steps indicated:
What do I do when my GSM managed switch does not boot up?
What to do when my managed switch does not boot?
Hope it helps.
DaneA
NETGEAR Community Team
Yamez
Oct 18, 2017Aspirant
DaneA wrote:Hi Thornweb,
Hope it helps.
DaneA
I would just like to confirm that following the instructions in the first link above worked for me - I now have full access to the CLI and web interface again! Thanks!
- DaneAOct 19, 2017NETGEAR Employee Retired
Hi Yamez,
Thanks for the confirmation. I'm glad to know that it worked for you. :)
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,
DaneA
