Bambam2014
Jan 30, 2018Aspirant
GSM7352s V2H1 Firmware Update
Hello, I am having problems after I updated the firmware on my GSM7352S V2H1 Switch. I used the web gui to update but now it is giving me an error. when I use the console it says "Wrong Image Format...
DaneA
Feb 01, 2018NETGEAR Employee Retired
Hi Bambam2014,
Welcome to the community! :)
Let us isolate the problem. Kindly answer the questions below:
a. What is the firmware version that you have uploaded to your GSM7352Sv2h1 switch?
b. Did you perform the firmware update using a PC that is directly connected to a LAN port of your GSM7352Sv2h1 switch?
c. What was the previous firmware version of the GSM7352Sv2h1 switch before you did the firmware update?
d. As of now, what is the behavior of the LED lights of the GSM7352Sv2h1 switch?
DaneA
NETGEAR Community Team
Bambam2014
Feb 01, 2018Aspirant
Hello,
Thanks for responding. I was trying to update the firmware to the newest 10.0.0.53 using the web GUI. I had a Ethernet cable plugged in to port 1 of the switch to the back of my computer. At the same time I also had a serial cable hooked to it as well. The firmware that it had on the switch was 8.0.3.11 I think. I do not remember what it had on it before. As of right now the fan light is green and the power light is orange. The web GUI said that the firmware update went fine then when it rebooted it did not work. I really do not know enough about Linux to do anything in uboot. If there is anything you could do for me would be very much appreciated.
- DaneAFeb 01, 2018NETGEAR Employee Retired
Jumping from the initial firmware v8.0.3.11 to the latest v10.0.0.53 is not advisable. The firmware upgrade procedure in your case should be done in a ladderized manner. It should be this way: update the firmware from v8.0.3.11 to v8.0.3.15 then from v8.0.3.15 to v8.0.3.25 and so on until you reach the latest v10.0.0.53. Then, perform a factory reset after upgrading the firmware to the latest version then reconfigure the settings from scratch in order to start clean using the latest firmware version.
Kindly access the following articles below and see if it helps:
What do I do when my FSM managed switch does not boot up?
What to do when my managed switch does not boot
DaneANETGEAR Community Team
- DaneAFeb 04, 2018NETGEAR Employee Retired
- Bambam2014Feb 09, 2018Aspirant
The articles that you sent me to did not help. I cant get into the utility menu. what I am getting when it boots is:
VFS: Cannot open root device "<NULL>" or unknown-block(0,0) Please append a correct "root=" boot option; here are the available partitions: 1f00 28416 mtdblock0 (driver?) 1f01 256 mtdblock1 (driver?) 1f02 4096 mtdblock2 (driver?) 1f03 2560 mtdblock3 (driver?) Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) Rebooting in 180 seconds..
I can send you a whole log file when I boot it if you want. Thanks
- DaneAFeb 11, 2018NETGEAR Employee Retired
It would be best that you to open a chat or online case with NETGEAR Support at anytime for further assistance. If ever the GSM7352Sv2h1 switch has been declared faulty, be ready to submit a .doc or .pdf copy of the Proof of Purchase or Sales Invoice of the GSM7352Sv2h1 switch for warranty verification. Then, if the hardware warranty is still valid, an online replacement will follow.
