oly_r
Jan 15, 2015Aspirant
GSM7352Sv2 - Ports 25-48 don't work
We have a GSM7352Sv2 - 48 Port Gigabit Layer 3 Stackable Managed Switch with 10g SFP+ ports for a lab environment network (no outside connectivity). We recently got to the point of needing more than ...
oly_r
Jan 30, 2015Aspirant
Sasword wrote: On the web-GUI, go to Switching>Ports>Port Configuration and check if 'Admin mode' is set to Enable. By default, the Admin mode should be enabled on each port.
ALL PORTS:
Normal, Enable, Enable, Enable, Auto, (mix of 1000mbps / unk), link up/down mix, enable, 1518
