tsgrandslam
Jan 30, 2020Aspirant
Having issues connecting to management interface over network with m4100 (GSM7248p)
I have been having an issue connecting to the switch management web GUI over a network. We have the following: company lan (10.0.20.0/23) : vlan 10 guest wifi lan (10.40.0.0/23) : vlan 11 company...
- Mar 14, 2020
Finally, after much tinkering the past few months I finally decided to go up to our business at night while we were closed so I could take the network offline and do some real testing, and after much frustration, I have finally got it to work correctly as expected. To anyone having similar issues this is what I had to do:
Download the text config startup file from the switch to my computer. I then opened it in a text editor and scrolled to the bottom of the file and saw some interface configurations like this:
interface vlan 1 routing ip address dhcp exit interface vlan 20 routing ip address 192.168.116.12 255.255.255.0 exit interface vlan 10 routing ip address 10.0.20.24 255.255.254.0 exit ip management vlan 20 exit
Since I am doing only L2 switching there was no need for routing. I deleted all those (but still left the global config set to disable it) and then completely deleted the vlan10 configs. the bottom of the file now looked like this:
interface vlan 1 routing ip address dhcp exit interface vlan 10 routing ip address dhcp exit interface vlan 20 routing ip address 192.168.116.12 255.255.255.0 exit ip management vlan 20 exit
I then uploaded it back to the switch, gave it time to load the new configurations and whala! Alas, success! It makes sense after checking that file but I still feel there is an issue with the way the web GUI makes configuration changes. Technically it should of still let me connect to the GUI with the 10.0.20.24 still configured to VLAN10 because I had set the mgmt vlan to VLAN20, not to mention I could ping 192.168.116.12 all along so I know the switch was aware that IP address belonged to itself somewhere. Also, the webGUI does not let you (that I could tell) simply delete a ip configuration on the management interface configuration page. It will throw an error if you attempt to leave it blank. So anyways, I will now only use the CLI to program this switch because it seems the GUI does not have full capabilities. If I am wrong about not being able to delete a mgmt interface config from a vlan altogether, someone please correct me.
tsgrandslam
Update: It seems i can connect to it over the old address it used to be assigned via DHCP on vlan 10 (10.0.20.24). I am trying to put all network management on a sperate network and deleted the static DHCP lease in our router as well as assigned the management vlan to vlan 20 in the switch as well as set a static IP for it. Why is the switch ignoring this?
- tsgrandslamFeb 01, 2020AspirantAfter reading other posts on this forum, I’m starting to wonder if this is a bug in the firmware for the m4100. It seems if the switch gets an address from a DHCP server on any Vlan it will use that address for the web mgmt address no matter what you try to set the mgmt vlan to be.
Any thoughts?- DaneAFeb 05, 2020NETGEAR Employee Retired
Welcome to the community! :)
As far as I have checked, there is no issue logged on the M4100 switch as per you have described on your post. Kindly try to reboot the M4100 switch and check if the same problem will occur.
What is the current firmware version of your M4100 switch?
DaneA
NETGEAR Community Team
- tsgrandslamMar 14, 2020Aspirant
Well here are similar cases I see:
In several cases all relevant configs are set to the desired management vlan, switch can be pinged from said mgmt vlan, but web interface (as well as telnet from my testing) will not connect.
Firmware Version 10.0.2.30 Boot Version B1.0.1.1 CPLD Version 0x2 Serial Number 3A9897********** AC OK Remote Not Present PoE Version 1.8.0.1 MAX PoE OFF - tsgrandslamMar 14, 2020Aspirant
