Budgie2
Oct 17, 2014Aspirant
Help with discriminating wifi AP traffic please
Hi,
I am seeking some general direction in the best way to discriminate and segregate wireless AP traffic using a managed switch.
I can set up several secure SSIDs on the AP and the AP can be set to tag traffic from each SSID with different Vlan IDs.
My question is how do I keep traffic from one SSID private and allow it to access both private network and also the WAN whereas the other SSID clients are only to be able to connect to WAN and not be able to see the private traffic. In other words how may I split the tagged packets from the AP at the switch?
Grateful for some guidance here on best approach please.
Budgie2
I am using an M4100-DG12 managed switch.
- fordemMentorPorts 2 & 3 are what would be considered VLAN trunk ports in that they are passing data for both VLANs to the VLAN aware access points.
If the first VLAN aware access point is supporting both SSIDs (Office & Guest) and separating the traffic correctly, then the second VLAN aware access point will also do so.
Port 7 is a guest VLAN port ONLY and whatever is connected there will only receive data for the guest VLAN.
Computers connected to the office SSID should have their traffic passed to the office VLAN which includes the wired LAN network and through it to the router and the WAN; computers connected to the guest SSID should have their traffic passed to the guest VLAN, (which is separated from the wired LAN) and through the router to the WAN.
Office users should have access to the WAN and the office network, guest users should have access only to the WAN. - Budgie2AspirantHi Fordem, Thanks again. I will give it a try tonight or in the morning. I am not only hindered by needing to keep guests on line but also I am a power injector short so things may be more complicated. Will keep it simple for the trials. Where my understanding falls down is with the internal routing in the switch. Your first reply included the advice:-
It was this I was expecting to do next but appears no longer necessary. Will get back to you after trial. Best wishes, BudgieThe next step will be to configure interVLAN routing on the switch and then set your access lists to prevent the guest VLAN from accessing the office VLAN. - fordemMentorThat approach had to be revised because of the configuration of the firewall you are using - as far as I can tell the firebox has multiple internal interfaces and you are already "separating" the office & guest networks there, allowing the switch configuration to be significantly simpler.
- Budgie2Aspirant
fordem wrote: That approach had to be revised because of the configuration of the firewall you are using - as far as I can tell the firebox has multiple internal interfaces and you are already "separating" the office & guest networks there, allowing the switch configuration to be significantly simpler.
Hi Fordem,
I was all set for testing but on Friday the power supply company had to shut us down while they changed a transformer and our systems did not come back up as they should.
In short the M4100 is now inaccessible. You will recall I had set a static IP for management but this could not be accessed, neither could the original default IP using a laptop directly connected.
In the end I did a factory reset with nothing connected. That should have enabled DHCP. I connected to DHCP server but no handshake took place.
Using USB port and Hyperterminal from XP laptop I could get in and run ezconfig but nothing could be saved consistently. I tried several factory resets and setting various Static IPs and enabling DHCP but still nothing.
Strangely the command set for the ezconfig is not all working. For example "show ip" gave me no result. "show network" did give me a result including the admin IP but this did not work. I may try CLI but meanwhile I am going to see if Netgear will stand by their lifetime guarantee and swap out the box.
Will get back to you when I have replacement hardware.
If you have any ideas on reading the above please let me know.
Budgie - fordemMentorA factory default M4100 should be accessible at an address in the 169.254 network (I don't remember what it is, but it's documented) - you will need to configure the computer being used for access at a 169.254 address and also to change this address when you set a new address on the M4100 (assuming you change the network portion of the address). Also - unlike most Netgear products you need to save any configuration changes as a separate step or they will be lost if the unit is powered off.
- Budgie2Aspirant
fordem wrote: A factory default M4100 should be accessible at an address in the 169.254 network (I don't remember what it is, but it's documented) - you will need to configure the computer being used for access at a 169.254 address and also to change this address when you set a new address on the M4100 (assuming you change the network portion of the address).
Hi Fordem,
Just to update you on the saga of my problems; the reset button does not do a full reset on the device I have.
The instruction set in ezconfig is either wrong or ezconfig has a bug, certainly several instructions do not work, including "show running-config" which is what ezconfig suggests you run to check after you have finished.
The only way I could get back to "as supplied" configuration and thence to the web interface was to root the operating system and do a factory reset from root.
I now believe the in-band static (fixed) IP causes problems as somebody advised in another thread. My problem with DHCP for the management address is finding out what address has been set as I cannot fix it using mac address in the DHCP server in the firebrick. (A limitation of the interface and my linux skills!) I can however check active leases and find the IP by looking for the mac address on list.
Trouble is, for reasons I do not understand, the last time I used DHCP the switch didn't keep the same IP even though all systems were left unchanged and powered 24/7.
Thank you again for all your help. I shall keep trying and report back in due course.
Regards.
Budgie2 - Budgie2AspirantHi Fordem,
Been working on other stuff for a while but am now able to return to this problem.
I now have all Vlan aware wifi APs, the M4100 is back to factory and I am ready to start over. I shall work with DHCP as static address caused too much grief.
This is just a quick note to ask if you are still there and able to help. Also should I start a new thread or persevere with this one?
Budgie2
