reda's avatar
reda
high internet connecting two GS724Tv4 SFP port to M4100-26G ProSafe 24-port Gigabit L2+
hello
i have the following setup
M4100-26G ProSafe 24-port Gigabit L2+  used as a core switch  firmware version Switch, 10.0.2.26, B1.0.1.1
two gs 724 t v4   sw ver 6.3.1.19  connected squancailly (one gs 724 v4 in the middle connected with two sfp one tword the core switch and other to another gs 724 v4
i have the core switch connected into fortigate 60 d firewall
when i am conneccting the core swtich directly to the firewal i have no issues on internet
but when i am connecting the spf port that connects both gs switches the interent statrs to be slow ( ping more than 350 ms ) and cuts
i have  no issues with a similar setup with diffrent versions of smart switchs
i am copying diffrent configurations for your refrance
please check and advice what the issue might be
Thank you in advance
1 Reply
  • Retired_Member's avatar
    Retired_Member
    Hi reda,
    Welcome to the community!
    I just want to understand your concern, could you please confirm am I right?
    Refer to this network topo:
    1. Is your network topo same like this? SFP connect between M4100, GS724Tv4-1 and GS724Tv4-2, right?
    2. When PC connect to M4100 switch, the internet connectivity is ok, but when PC connect to GS724Tv-1 and GS724Tv-2, the internet connectivity is slow, right?
    3. Could you please descirbe the configuration for all related connect ports(between Firewall and M4100, M4100 and GS724Tv4-1, GS724Tv4-1 and GS724Tv4-2)? Such as: VLAN config, PVID config, and port speed...
    Hope it helps!
    EricZ
    NETGEAR employee
ProSupport for Business
