bartam
Mar 07, 2018Aspirant
How can I tell whether a switch (GS108Tv2) supports EAP-TLS?
Hi everyone, I need to test a 802.1X supplicant which uses specificically the EAP-TLS protocol to communicate between the device and the switch. How can I tell whether a particular switch support...
- Mar 08, 2018
According to this tutorial
EAP-TLS should work on GS108Tv2 (and other switches from the same cathegory) if you do a firmware update.
schumaku
Mar 07, 2018Guru - Experienced User
Hi LaurentMa ... of course there are no issues with EAP-MD5 (have several deployments on the field with these small swiches) as well as EAP-TLS on the newer Smart Managed Pro. However, I don't get it why and how using an alternate authentication should break things. There is no change in the communicaiton process - when it comes to the switch - between the supplicant and the switch resp. the switch and the RADIUS server. Tell me what I've missed please.
bartam
Mar 08, 2018Aspirant
